Sound like a great deal to me man! Just leme know on measurements n stuffI can come down 100, It has brake brackets on it too.
I didnt realize QP was that cheap
Is that 56.5" axle flange to flange, or housing flange to flange? Stock is 58" for the axle flanges and 52.125" for housing. If its narrowed the frame would need to be notched. It would actually limit wheel and tire use.The spring perches are 36in center to center
Flange to flange 56.5, Which I think may be a bit narrowed, but that gives your a bit more wheel options if it is
The hump is centered which means the pinion is about 2in to the right (which doesnt really effect anything) circle track guys do this so they can lower the upper mounts even although these arent lowered.
I will have to do some measuring on the spring perches.The spring perches are 36in center to center
My spring perches are not 36. I dont think that rear end will fit. Thank you but i think i will have to pass.Housing flanges, I guess I was thinking the stock rear was wider than that.
So add some allstar cut to fit axles with the 2.5 offset and you're at 61.5 so with the same wheels they will be 1.75 further out on each side.
The allstar axles come with the bearing pre-installed, there is an 1/8 spacer under the bearing that when taken out will make the brake offset 2-3/8th So you could take those out and only be 1.5 wider on each side.
My thinking with a narrow rear end having more wheel choice.
You can always space out to a high back space wheel on a narrow rear,
You cant take take material away from a rear end to fit low back space wheels in the wheel well.
