92 Corvette LT1 and 6speed trans
With Ls I can keep my automatic and more parts available at a decent price,
Not sure what automatic transmission you have or whether you want to keep it. But 92-93 Corvette and 93 F body still had the old non electronic 700r4. Newer models used the 4L60E as did the LS powered 98-02 F bodies and many 1/2 ton trucks up to about 2008.
I would not let that be a deciding factor. You will have to change and buy a lot more items to LS swap it........mounts, oil pan and you will still have wiring to do.
Go on the Impala SS forums. It seems there are a lot more turbo and supercharged Impala (and other B bodies) then LT1 Fbodies. Piston wise they were hypereuctectic pistons just like the LS and newer LT engines use. No difference in durability if the tune is correct........and trust me guys break and melt stock pistons all the time.
U havent seen it because durring the era of LT1's boost was a fairly new thing.
Mainly you seen paxton superchargers
