Hickson856 said:I stuck a big car 400 out of 69 into my 80 LeMans and didn't know those adapters even existed. I ended up using the original motor mounts for the engine sitting it into the frame, leveling it and moving the tail on the transmission like others have mentioned to get it to line up, marked the perimeter of the motor mount with a soapstone onto the frame, pulled the motor back out, made some measurements, drilled new holes and bolted the mounts in that way. I know the way I did it sounds rediculous and that's cause it probably is, but it sits pretty now.
And as far as the front frame of your lemans, if its still not sitting right, as others have mentioned keep moving it this way and that, making sure the transmission is lining up right and every thing is still operable (shifter linkage, I had to move my motor forwards so that still worked without hitting), and it seemed as though the frame that the motor sits in isn't symmetrical, maybe it's just me or the frustration level I had reached but it seemed that where you have the absolute center of the frame, the angle that goes up to the left to the frame rail didn't match the angle that went up to the right. Check it out for yourself, I did it with a level and a plumb-bob but like I said, at this point I could've just reached a point of haziness where nothing seemed to make sense.
