A/C Swap Parts
Did you use an Olds or F body condenser?
Will F body hose work on the Olds condenser?
to be honest, it was on a c10 truck, i was able to use all the other original parts. if you look up the parts on oreilly or some other parts site you can find the connection sizes.
a few years later, i ended up upgrading to a sanden style compressor with the dirty dingo kit: r4 to sanden serpentine adapter
F body hoses work very well. I put them on my GP they just need some gentle twisting. The f body condenser will also fit I used that as well.
Jamie, I used a serpentine setup from an '88 Firebird on my Monte. I used the suction/discharge hose assembly from the Firebird, with some gentle tweaking, and a condenser from a Cutlass with the 307 Olds. It worked fine. Are you using the newer alternator? I believe there is an adapter harness that allows you to plug the newer alternator into the existing vehicle harness.
Thanks for the info.
And yes I got a connector for the alternator
I've ordered an Olds Cutlass 307ci Condenser, Evaporator, Accumulator, Orifice tube and...
A suction/discharge hose assembly for an F body. Also an electrical connector for the compressor.
Question
-There is no diode on the new connector for the compressor clutch like the old compressor connector. Should I install one?
Sweet I need a condensor, good to know. I need to price out a 3rd gen F body vs a Olds G body one.
You are going to need a liquid line (small diameter hard line that runs from the evaporator to the condenser) off of a Cutlass. I sourced mine on here (a used one). I'm not aware of them being available new.
I had to use my original since I could not find a reproduction, it was the only part I didn't replace with a new one
Ya, I looked and couldn't find one. I'll modify the original one or I was thinking of just making a new one. Thanks.
