I've never heard of that. Are they available or home made? Most books advise oiling or greasing the seal/shaft so that doesn't happen. If the shaft is splined I usually wrap it with masking tape to protect the seal. A companion flange is pretty smooth at the end.
You make them yourself. Its a oldtimer trick and generally were made out of tin shim stock but you can cut one oug of a soda can.
