I really don’t know if the compressor is on the same side but the condenser is on the driver sideIf your compressor is in the exact same place as the V6 mode, then you could go either way I would think. But if you had to move it, which is likely, then you would be better off buying for the current application. I'm not sure if the condenser has the hose connections on the passenger side or not. But you might have to do something different there if your current application calls for condenser hookup on the opposite side of where you need.
I’m having a hard time finding that line .Go with a hose for a 305 if your condenser has the inlet/outlet on the driver's side. You will need to source a good used liquid line (hard line that runs from the evaporator to the condenser and runs on top of the fan shroud.
