If he did a load test on the battery and alt then it's probably fine. Sounds like a short slowly draining juice. Sometimes it can be a slight short not enough to blow a fuse, but will drain the batt.
Bonnewagon said:If he did a load test on the battery and alt then it's probably fine. Sounds like a short slowly draining juice. Sometimes it can be a slight short not enough to blow a fuse, but will drain the batt.
Bonnewagon said:Naw, he said "light meter" so I assumed the mechanic did a load test. If he didn't shame on him. If not then he should start right there and get it done just to verify the batt and alt are OK. And hook up all the grounds straps. Yeah the other topic with the grounds was giving me a headache. I still think he could have a tiny short draining power. I've seen as much as 3 volts leaking to ground just from an acidy covered battery.
