AC Keeps Shutting Off (Photos)
10,583
14,332
If he did a load test on the battery and alt then it's probably fine. Sounds like a short slowly draining juice. Sometimes it can be a slight short not enough to blow a fuse, but will drain the batt.
jrm81bu
3,000
48
Antwerp, OH
I didn't see where he did an actual load test. Have you seen the other thread too?
10,583
14,332
Naw, he said "light meter" so I assumed the mechanic did a load test. If he didn't shame on him. If not then he should start right there and get it done just to verify the batt and alt are OK. And hook up all the grounds straps. Yeah the other topic with the grounds was giving me a headache. I still think he could have a tiny short draining power. I've seen as much as 3 volts leaking to ground just from an acidy covered battery.
jrm81bu
3,000
48
Antwerp, OH
Oh ok, I thought I mighta missed something. I'm not exactly sure what that "light test" is. He could definetly still have a draw somewhere. It just kinda hit me when he said the blower was slowing when he gave it gas, then wouldn't start after shutting it down. Seems like it was running off the battery alone.
1984CuttySupreme
34
Altamonte Springs, FL
For the light test they were just checking to see if any current was being drawn while the car was off. It lit up slightly so they said there is something drawing power but not enough to make the car go dead if ran regularly. I'm kinda stuck right now, I put the battery on a charger again last night but it's still dead. I'm using a different charger from before so hopefully the charger is just not working properly. I'd hate for the battery to be bad since it's only 2 weeks old. Once I get it running again I'm taking it to a different shop. lol
Doober
1,253
20
38
Swartz Creek, MI/Tucson, AZ
Man it sounds like you're havin' all kinds of fun with this car :lol: I'd definitely get the battery & alternator issue straightened out, then see if it still has the same issues. If it does we can go from there, it's hard to diagnose a seemingly odd electrical issue with a poor electrical system base. Once the alternator/battery are in proper working order and if it's still melting that fuse like you say, there's likely a short in the circuit somewhere.
jrm81bu
3,000
48
Antwerp, OH
I see, ya that kinda test does nothing for the alternator. I hope this battery charger isn't working for your sake. However i did say that continueing the cycle of charging it then driving it til you have to charge it again would kill the battery. Hope you get this worked out soon.
10,583
14,332
Yeah, do a real load test. You need to start with a fully charged battery, and it gets tested with no load on it. Then with the car running, a load is put on the system and it measures what the alternator is doing about it. That will tell you right away what you have to begin with. If all checks out, then start searching for the culprit sucking your juice. It looks like this.
1984CuttySupreme
34
Well I picked my car up from the shop today. The charging system seems a lot better now. The AC was working fine for a few minutes until the compressor started locking up and squealing. Then I noticed that when I turned off the AC, the compressor shut off but the blower remained on. So it's back to the shop tomorrow, unless you guys have an idea. I noticed they ran a wire out of where the fuse for the AC goes.
Another question, because I switched to a 4.1 Buick motor, do I need a different AC compressor? Or are the compressors for the 3.8 oldsmobile motor and the 4.1 buick motor the same?
jrm81bu
3,000
48
Antwerp, OH
How fast does the blower motor continue to run? Someone else mentioned( Blake442 maybe) that the blower motor will continue to run on low with the heat/ac off. Supposed to act as a vent or something. That is if i'm remebering any of this right, lol.
