I have a few ideas but I need a little advice. Currently the stock pedal hits the trans tunnel and prevents the carb from opening all the way. I can only get the engine to reach 3k rpm. Would it be better to cut the bottom off the pedal or move the pedal away from the firewall?
For reference I have a 1980 Supreme Brougham swapped to a 350 chevy. I'm using the Summit street/strip 600 cfm (Holley) four barrel single pump. the cable and pedal are original.
