The ET of the car you build has is not a gauge for your knowledge. Also circle track cars and full tube drag cars are not stock chassis G bodies.
The opinion comes from people who have a car that is 30 to 50 years old. It drove fine and made it through a couple 4 wheel alignments. Everything is good, then one day they slap a wide rear tire and rim on and bang, they want to shift their rear housing sideways in the car. 90% of the time, this is the body mounts, the bodies fault or poorly hung quarter panels. Now you are going to run a short and a long upper arm, the lower arms will shift slightly over and the rear will Not be centered because the body is being used as a centering gauge. This is incorrect.
Team Z talks about a centerline. If the rear is out, personally I would want to find out WHY it's out. If it is the upper mounting points then That is the problem. Now it's your choice to fix the mount or run unequal length uppers. I have plumbed so many cars and will tell you OEM mounting points are almost never out. So with equal length arms the rear housing will be centered to withing a reasonable tolerance of 1/8".
So this is all words and assumptions. Let's make this into numbers. If a professional chassis was built or a new 2021 Ram right off the assembly line was built. If the rear needed to be shifted over 1/8" according to the alignment machine. We are all going to adjust to get it right in the middle of the spec, even me. Same as a panhard set up which has no heavy angled uppers to center a rear, adjust and move on. On a 4 link car, any more than 1/4" I would seriously look into WHY and correct the problem, like a bent chassis, incorrectly placed upper mounting points, axle flange to rear housing flange difference instead of running 2 different length uppers.
The lowers are pushing straight on a launch, so 2 different length lowers to correct for thrust would probably have little effect on a drag car. They will still both push the chassis forward.
The uppers are Not straight. They are on a heavy almost 45 degree angle. They pull hard on a launch and on a 7 second ride, having those at an equal length is something I'd aim for.
