Adjusting rear control arms?
Chill out gents. Keep it civil, each his own.
Well as someone who has worked in the automotive field for over 30 years I can tell you that your info on centering the wheel is wrong. Have you ever performed an alignment? You will find guys will find the center or high point of the steering box or rack. Then make sure the steering wheel is indexed if it can be installed in more than one position. Then the tie rods are adjusted. This of course after camber and caster are adjusted or verified to be in spec.
You can go into any shop that does alignments and that is the way it is done. I can assure you that they are not worrying if the center link is perfectly centered. The alignment is correct If the steering wheel is straight and the car goes down the road straight. But I'm sure you will have another cute response.
That would be refreshing to see. Most shops around here set the toe and let it go. No way in hell are they trying to pull a steering wheel!
Well when you get one with the steering wheel radically off and nothing is visibly bent you will. I worked on an 80's Chevy Silverado and went through this. It turned out that the remanufactured steering box was put together a tooth off. That one had me scratching my head as everything was fine prior to the replacement of the box.
  • Wow
Reactions: fleming442
I went to tech school for this when gnvair was just a young pup in the auto service industry and this is exactly how they taught us to do alignments. Box/rack centered, everything else tweaked to match the center.
In real life, you'll be lucky to get it back with the steering wheel straight. These guys are challenged for time. Although sometimes peeking into the bays and watching what goes on tells me a different story. Had a rack replaced under warranty at the dealership in the wife's old Caddy due to rack seal leakage (they caught it during one of those free oil change visit) and they replaced the rack. They gave me back the car with the wheel about 1/2" off off to the right. I gave it back and said they could do better than that, I surely could. Not enough time to do it right the first time, but always time to do it again. Eventually they got it to within about a mm of being straight like it was when I brought it in, after 2 more tries. I gave up.
I am getting pretty close to buying myself a set of caster/camber alignment plates and doing all my alignments myself. Toe and go is all you get from my experience.
I swapped lower control arms and upper ball joints on my daily last month. I put it together and the camber was real off so I got it sorta close. I had the shop down the road align it and all it said was 'adjusted toe' in the notes. Literally my eyeball camber adjustment was good enough for them. For the $80 I paid them, I should have just grabbed my tape measure and did the toe myself.
And PS. I aligned the rear in my 2+2 to center the rear and fit the drag radials. Stock lower arms boxed with poly bushings, uppers are dirt car heims on one side and speedway rotojoints in the housing.
The rear sat about 3/8" to the right.
I set the new adjustable arms to the same length as factory, dialed in the pinion angle and then turned each about 1/4 turn at a time to center the rear. You are talking like 1/4" of length difference b/w the arms to get it centered unless its real bad. That slight difference isn't going to cause anything to bind especially since almost all adjustable arms have heims or rotojoints anyways.
I brought my GP to a corvette specialist for a wheel alignment. I told the owner what settings I want and when the spec sheet printed out the caster setting was greyed out, the owner argued with me that my car has no caster adjustments... :popcorn:
Lowers adjust thrust angle if adjusted independently, wheelbase if together same direction.
Uppers adjust left to right under the car if adjusted independently, pinion angle if together in same direction.
Call the shop if you need to hear it instead of read it. It's not that challenging of a process.
This is the exact issue I was having, the lowers didn’t move the axle left or right, just put angle into it. That’s where I was getting confused, not to mention I was just going by eye via hacked off quad shock mounts.
