Advice please
Buy it.
I'll give you $300 for the title, vin plate and cowl take.
I realize that this happens and has its valid uses, but generally speaking this isn't legal. Not trying to hijack the thread, just stating facts. (plus it was reported and I kinda need to say something...). It's on the dark side of a gray area, for sure.
Carry on.
Carry on.
Thanks for chiming in. I wasn’t planning on doing it anyways.. it is a felony..
I think I’ll try and get it tho..
I’ll keep you updated.. 😎🏁
From what it sounds like (since there are no pictures) it is a complete car and if you get it for around $500 even if you decide to not keep it you can probably at least make double or more parting it out.
Reactions: Dayzedandkonfuzed
Did someone say pics?? Put a hot battery on it and some gas it fired up and I drove it home about 7 miles tags went out in 2015 😎
Wow! Once in a while, you win! Get that title in your name before anything silly happens to it.
You're already in a good place with a SBC that looks stock.
Put something on that rust to slow it down unless you will be parking it inside. Vacuum all the leaves out of the cowl area and clean out the drain flap on the bottom of the heater box.
No matter where you keep it I'd Clear coat over the existing rust/paint and seal in that patina, run it as is. Instant sleeper.
Thats the good rust, just sunburnt paint, not rot/flaking cancer.
Reactions: 565bbchevy
Okay, all the above plus, was it stored outside and on what kind of surface? Lots of grass?? Look for rotten floor pans under the carpeting, and rusted body mounts and frame pockets. Also look for various tenants hiding in the various nooks and crannies. Examples can include mice, coons, squirrels, snakes, spiders, and a myriad or other creep-crawlies. Check the wiring closely under the dash. Mice and squirrels both love to chew on the insulation, just because they can. Do the same for the engine bay and particularly down at the starter. One place to check is the heater box as mice can get in there and it is often overlooked until you need heat and then😭
Other things to consider, pull the oil dipstick and the t-mission stick and check them for their respective oils. Sounding nasty here but use your fingers and nose to touch and smell those lubricants; your senses will tell you more about the condition of the fluids than you might think.
Do not try to start or drive it as is. Your immediate to do list, apart from an oil and filter change, needs to include a close look at the brake lines and the fuel lines. Pump out the fuel tank and go fresh. Add a new filter as insurance at the carb but if you go with an external can,. lose the internal filter behind the fuel line fitting on the carb. Two filters here are not better than one. New air cleaner... and the list will grow as others on the board add their items of interest to it.
Reactions: Woody1980
