I thought I'd post this in case anyone is considering buying one of these.
- The hole spacing is very tight so you may want to drill them out a bit to give you a little room to play with.
- The hole for the cushion that mounts against the radiator is a bit off.
- And most importantly, I had to trim the recessed area where the hood spring passes to rest on the core support.
