Thanks man. The front of the console has a stock bracket that is vertical. It bolts up to the inside front edge of the breadbox area. The original mounting was modified to make the Hurst work. My shifter is mounted directly to the floor, and the plastic shifter plate is cutout to fit properly.That looks awesome,the rear bolts line up with the rear of the shifter it’s the front set that don’t even line up on the bracket I have.and how do you support the front of the console,only one screw hole on the top of the shifter.i thought it was a simple swap lol
Silly me, getting all excited and whatnot...
I saw the V, and thought Verti-gate. So sad.
The reverse light switch is on the column, only plug is for the lock up switch.Dosent the reverse lights triggered from the plug on the side of the 200-4r ?
