Way back when I was working on the 81 I posted a question about the transmission cooling lines. Back then I wanted to use hard lines. I bought a set of SS lines from Inline for a TH350 and tweaked them to fit the TH400. They seemed to work. Now that the cars running I found a slight leak from the upper line. Not from the threads. Its from the center of the fitting around the tube. I put these on before the headers when there was a lot of room. Now, not so much. Cant get a wrench on to play with it. Not even a stubby. Im sure its the flare that isnt seated.
So now Im considering using a set of braided SS. What size AN would be used for that and how have you guys run them ? 90 degree at the radiator ? Attached to what ? The inner ? And what clamps to mount them ? Pictures would be a big help.
