AN Cooling LInes
Can someone tell me what adapter I would need for the radiator internal cooler? I am using -6AN, I'm just not sure what the other end should be and size.
Reactions: 64nailhead
I try to use the steel equivalent of the fitting mc1984ss posted do that I can get a proper seal.
But I have that same style fitting in my radiator as well.
When I worked for the "Bent on Perfection" aftermarket supplier the 5/16 tube nuts were 1/2-20. The adapters you are looking for should be the 1/2-20 inverted male to -6AN.
This should get the job done on the radiator side.
Reactions: tngbody and Rktpwrd
