Another suspension question?
Hutch949
37
2
Since I put the lowering springs on lm thinking of cutting a little off the front springs, so I was crawling around underneath and noticed that the front sway bar is now tilted upward pretty good.Do I need shorter end links now or is there such a thing.It also looked like the back springs are so compressed it appears that 4 of the coils at the top of the spring are actually touching each other with only 2.5 coils to compress when you ride over some bumps in the road.
UNGN
3,048
3,264
Southlake, TX
Cut the sleeves on the bolts to level the bar. Pretty easy to do.
20,397
With the ones I use I'd run out of thread on the bolts if I cut the sleeves so he might have to change the bolts as well. I left mine as they were when I dropped the GP
Hutch949
37
2
It looks as if the solid space is too far between the rubber bushings. I looked on summit racing and found one about 3/4 of an inch shorter.For $23.00 I think I'll try that one.Thanks guys.
MC96
458
493
Energy sells an end link kit with different length spacers, so you can mix and match to find the correct length. There is a diagram in their catalog that shows the end of the sway bar needs to be level with the lower control arm. I would've just cut the sleeve.
Just posting for people who find this thread in the future.
UNGN
3,048
3,264
Southlake, TX
Factory sway bar bolts are pretty puny at the threads. A trip to Lowes would solve this.
marcar1993
702
209
New Jersey
You could cut the sleeve, then move the cut part of the sleeve to the thread side of the bar on the link. Throw a washer on it and now the sleeve is the same effective length, but the bar is still moved downwards to a middle point in the link.
