Thanks will check those out! I just replaced the pinion seal a few weeks ago, had a very very slight leak. Didn’t see and play back there. I think I’m going to bite the bullet and have the driveshaft balanced and u joints replaced.check your rear axles to see if the axle bearing has caused a groove in an axle, also check to see if the pinion seal is leaking on the rear, that is an indication a problem with the bearing
