Anubis' LS swapped 442 - On the Dyno at BEI
Nice car. Let's stay in touch. I've got 400HP/500lb.ft. now in my BBO and have not bothered to try to improve that because I have [had] no traction . . . as 13.4/103 would show.
When I get her back on the road with the changes I'm making in my build, that should give you a general idea what you will minimally have to do to get what you have now to the ground AND keep a decent road driver. Beyond that, it is a matter of what you want to do with the car? I want it to drive on rails and do the twisties as well as a gbody can? You know, that, holy sh*t is that an old Olds out there? That's the vibe I'm after.
Sorry for the delay.....Gary was surprisingly close.
Here are the results. It fell short of my goal to make over 400 at the wheels. I figure the parasitic loss from the 4L80 isn't helping but I wanted a bullet proof transmission. Max power at 5700 RPM 388 RWHP Torque 372 ft lbs.
The numbers fall in line with what Camaro guys are seeing with similar mods. Next step is to take it to the track. The car is fully loaded and weighs 3510 lbs.
Car is sweeet!!
You may have had higher numbers if they used more than one fan.
One fan isn't enough to simulate the open road.
