I installed a 4L80M in my 79 wagon, but yet to run it, the car is being upgraded. I was looking for an overdrive and got a good deal on the 4L80M, as the original owner went to a glide for drag racing. The trans was made with a full manual valve body and built to endure way more power than I will be putting to it with a 4500 stall converter. It fit under the floor OK, but I needed to make a custom cross member, that also required fabricating two mounting perches on the frame rails for the cross member. I weld, so the fabrication was not an issue. The trans was engineered longer for OD gear room.Get ready for information overload https://www.google.com/webhp?source...-8#q=4l80e+gbody+site:gbodyforum.com&safe=off
