GBOTM April '23 ENTRIES - Spring! (and Shocks, Bushings... SUSPENSION)
Northernregal
wingnutks
Tony1968
81cutlass
64nailhead
Didn't you guys do some things?....
Rktpwrd 1 month late huh?
Robert Downey Jr Shrug GIF by MOODMAN
No one wants to see my garbage
A few pics of my Viking coil overs and UMI control arms for front and rear. Front is Blazer spindles, there is a thread regarding the steering angle. Max Brakes.
Rear has adjustable lower mounting points.
Too early to call for any stance pictures. It's fully adjustable and the ride height has not been determined yet. There is no engine in the car.
Here is my submission!
List of suspension mods:
Front:
Upper A Arms extended 1 inch at the ears, fully molded and reinforced then chromed.
Lower A Arms reinforced, molded then chromed. Moog bushings throughout.
Spindles reinforced then chromed.
All chrome ball joints, all chrome steering links.
Reinforced spring pockets and welded closed all gaps in spring pockets. 3 ton hopping coils up front with 8 inch Hoppos cylinders with a standard cup. Chrome brake calipers and dust shields. Also chromed the jounce bars.
Rear:
Reinforced spring perches.
Chrome 1 ton coils on deep cups with 12 inch Hoppos cylinders. Reinforced rear frame arches. Adjustable upper and lower trailing arms chromed. Fully reinforced rear axle with power balls welded on for the cylinders then chromed. Also installed Black Magic axle pivots to take stress off the ears on the pumpkin at extreme angles. Brake drums and backing plates chromed. Chrome gas tank cover with chrome straps and chrome spare tire well.
Trunk:
Built and welded in the pump and battery rack, tying the frame together for strength. Color matched to the car. Two Hoppos pumps with #9 gears with vented bearing caps all chrome. 4 Delta dumps chromed with stainless return lines. 6 Napa Group 31 batteries wired up sending 36 volts to each pump, running through 6 Accumax solenoids. All this is controlled by 6 switches...front, back, each side and both rear corners for 3 wheeling.
