Axle swaps
85grandprix350
6
Wisconsin
Are the gm 7.5 and gm 7.625 axle shafts/differential interchangeable? Is a g body axle the same width as a 1992 gmc jimmy axle? Opinions on buying a used limited slip Yukon gear and axle?
85grandprix350
6
Wisconsin
Did you count the splines are they 28 or 26 and what carrier do you plan on using
As far as I know the jimmy has 28 splines and a 7.625 rear end my gbody has 26 spline and a 7.5 rear end can I put the axle shafts and differential from the jimmy into the axle of my gbody?
1320John$$$
951
2,043
Pennsylvania
You can but I think the jimmy axles are a little longer the carrier will also fit I kind a remember the pinion bearing I think Has to be changed from the jimmy but not 100% sure don’t quote me on it
UC645
1,086
3,080
Kittanning, Pa
The 7.5 and 7.6 should use the same housing, if I’m remembering correctly.
There’s also a lot of good info in here:
As for the fine details, I’m not really sure. If you’re upgrading to hold more power, just save your money for a better axle assembly. Junkyard or otherwise.
85grandprix350
6
Wisconsin
I can get a good deal on a limited slip for the gm 7.625 rear end with 28 spline so I need to know the axle lengths of a g body and jimmy
UC645
1,086
3,080
Kittanning, Pa
G body is 28-7/16 inches long
Blazer/Jimmy is kind of a crapshoot. But the most common number I’ve found is 26 and a half inches long.
I’d just grab the carrier if you really want it, the blazers and S10s sometimes used an offset rear axle housing and it’s not worth the hassle to find out which is which.
79 USA 1
1,065
2,039
Cheektowaga, New York
The internals from the 7.5 and the 7.625 do intrechange including the ring and pinion. Most of the 7.625's are 28 spline axles which require aftermarket axles or a set of 28 spline axles from a G Body 8.5. (Grand National or 442)
