Hi,
I just signed up to this forum looking for some advice. I have an 85 Monte SS and I am looking to install a B&M 144 that I got for a good price. The car has a freshly rebuilt 355 with a very low mileage rebuilt 200r4 transmission with a shift kit. I'm upgrading the fuel system to a larger mechanical fuel pump and a boost referenced blower carb from Holley. I won't be running too much boost(6psi max) to avoid detonation, ect. The only few things I'm having a hard time with are;
1.) Carb, throttle, and TV linkage - I have been searching for a cost effective bracket that I can use with my existing cables with that will correct the change in height with the new addition of the blower. Does any one know of any solutions or kits that I could use? Pictures and part info will help.
2.) Cowl Induction Hoods - I really want a steel hood but it looks like the only make them up to 2 inches for my car. Would a 144 be able to squeeze under a 2" cowl hood with a low profile air cleaner that will still clean the intake air effectively? Please let me know of any low profile air cleaners to use.
3.) Return Fuel Line Delete - Considering I bought the car with the original L69 305 and all of the smog equipment with it, while I was swapping out the 305 for the 355, I decided to keep the same stock mechanical fuel pump that had the return line. Considering that the new larger pump I will be installing only has 1 in and 1 out, should I be able to delete the fuel line or at least plug it up with little to no issues? I called the guys from summit and Holley and they said I should be ok. I just wanted some reassurance.
Any advice would really help.
Thanks
Thanks
