My B&M Megashifter gets stuck in 2nd gear when in ratchet mode. Does anyone know how I can fix this? I've already replaced the shift cable because it did have a kink in it, but it still gets stuck.
What I would do is with the cable hooked up have a friend run the ratchet through the gears .all of the gears, not just ratchet. Like the other guy said make sure you are in thre right hole with the right braket.Qdub24 said:My B&M Megashifter gets stuck in 2nd gear when in ratchet mode. Does anyone know how I can fix this? I've already replaced the shift cable because it did have a kink in it, but it still gets stuck.
