B&M shifter + reverse lights
Mr.Monte81
48
34
42
The Monte(81 LS) has a B&M Pro Stick and I would like to get the reverse lights working. There are 2 red wires with female connectors down at the base of the Pro Stick. Do the green wires from the reverse lights get spliced into 1 wire that goes to the shifter switch? If that's the case, I assume the second red wire would've for the safety switch?
Yep! Got one of them. Not sure if both red wires go to it, or just one of them.
There will be a separate switch for neutral safety. Basically all you're doing is wiring that switch inline with your reverse light wiring (should be a green wire). It's a normally open circuit until you engage reverse which closes the switch.
Keep in mind that the reverse lights need voltage to the switch. So, if one of your reds is ignition hot, then the other probably goes to the green for the lights. Throw a 5a blade fuse across them, and turn the key on. If the lights come on, throw them both to the switch. If the fuse blows, further investigation is required.
the back up lights wires are blue and green, the blue being the switched hot wire. If you still have the linkage from the column to the transmission the switch on the column near the firewall will still work. If you don't have the linkage you may have to turn the column near the dash counter clockwise by had to remove the key
Those red wire might be a neutral safety switch the stock wires for the revers light are on the top of the column there should be a green and a blue wire. Good way to test, put the wire ends together if the car doesn't start that thats the natural safety switch if the reverse light come on thats the reverse wires.
Well... Decided to look under the carpet first. Kind of glad I did! 😋 I did notice a blue wire that was cut when I was under there. I'll have to take a better look and trace it. Then, should I splice both reverse light wires to one of the red wires?
Reactions: Injectedcutty
