They used to go on top of the column, so they probably aren't too far under the carpet in the footwell.
Ah! If I'm seeing it right, the CCCS would be in the cab? If so, I'm tapping into that wire. 😝
If you look at the photo I posted on the first page you can see that the two wires that go to the reverse light switch are blue and green. Whenever I try to wire stuff I always make sure I use the original colors if I can.Got it!! I ran a wire from the back up fuse and from the light green wire terminal at the fuse box harness to the switch. Got 14g wire to replace those old switch wires at the shifter.
I dropped the column and couldn't find those 2 wires. Only ones I found were black/red stripe and red/black stripe. It looked like the last owner had them hooked up at some point as the 2 wires that run to the shifter were cut. I am planning on looking behind the fuse box to find that blue wire and tap into that.If you look at the photo I posted on the first page you can see that the two wires that go to the reverse light switch are blue and green. Whenever I try to wire stuff I always make sure I use the original colors if I can.
