and or the rear the stock uppers will flex when in a bind situation but you can't box then or when they bind the rear will upset the handling so the best cure for that is tubular uppers with a spherical joint.
*Covered. I'm using joints on my rear CAs. My front bar is a UMI piece. Ripped the stock mounting bolts out on a test drive. That's what has me worried about a bigger bar but I suppose it's nothing a welder can't fix. My rear bar is of the same make but it's an older model that mounts to the lower rear control arms. I might experiment with removing it for a couple runs, but I need to make it to some events and actually learn how to drive first.pontiacgp said:and or the rear the stock uppers will flex when in a bind situation but you can't box then or when they bind the rear will upset the handling so the best cure for that is tubular uppers with a spherical joint.
