Bad to run to big a carb.
BowtiesOnly
42
I've only got a mildly built 350, with an est. 350 hp. and it's got a 750 cfm carb on it, which is broken, and stuck wide open. I know I need to downsize to a 600, but I'm curious if running it is bad for the engine. I would like to wait til next spring to do so, probably after only another 500-1000 miles on the car, I'm just curious if this is at all bad for the engine.
G_Body_Enthusiast
1,056
16
38
Louisville, kentucky
you tell us, do you think driving a car with a carb stuck wide open is a good or bad idea? what do you think will happen when you put it in drive from neutral? do you think the transmission will like that?
chevy2480
1,245
6
38
williamstown nj 08094
+2 you also run the risk of washing fuel past rings causing ring failure and getting in oil if to rich. not good
RockSS
276
2
Enfield Ct
first of all I dont think thats to big of a carb all depends on how you drive and set - up how ever if your having a problem with it sticking wide open then you need to address that ASAP BTW heres a CFM calculator
http://www.wallaceracing.com/intakecfm.php
CHRIS.O
1,432
36
MI
If the carb that is on it now only needs minor work I would just keep it.
dogsht
2,003
9
36
Dayton, OH
Set up correctly it is not too big.
454muscle
1,242
15
Ontario, Canada eh!
Doesn't the huge cfm carb only suck in the gas/air that it needs, based on vacuum?
If the flaps are stuck open, you'd likely run lean.
Check the exhaust at the back, do you smell gasoline, or see any gas dripping, and what kind of smoke, if any do you get... to see if it's running rich.
Running too lean or too rich (both) will damage piston rings.
If you're running and idling smooth, you might be ok, just make sure you're not running lean.
BowtiesOnly
42
I know I'm running rich, it idles fine it's just a pretty strong gas smell when I'm on the throttle. It's only backfired a few times on me in a few hundred miles but that was after low rpm highway for 10-15+ minutes. The carb is not broken, It just can't be adjusted, the pins or whatever they are called are broken for adjusting, so it's set all the way up, is what I meant, sorry for the confusion. It runs fine, and the rpms don't hop around, I've just been told by multiple people a 750 is too big for the motor, and that 600-650 would be better. So after this, do you guys think itd be that awful for it to run another 500 miles on it as is? This is a car that will not see more than 3000k miles in a summer, as long as I own it... I appreciate all input so far.
chevy2480
1,245
6
38
I would go with a 600-650 because thats plenty. I dont care how you adjust a 750 its way to big. Thats why carb matching is important.
