So I had a friend who is a licensed mechanic come by and tell me that I most likely had a sticky needle in my lifter on the carb.
So to tap it to loosen it out or make it work, but if that didn't work to just give it up and buy a new one.
But the tapping worked, as far as I can tell.
Why I say that is, I left my car turned over while I worked on it and it killed my battery so I charged it at auto zone and brought it home.
The positive (+) cable every time I would try to start it, it wouldn't start and would smoke so I checked it and saw it was stripped and cracked.
So I assumed that was it so i bought new bolts.
Put it on the cable and it still didn't start, now the black one was smoking but it was a perfect bolt.
But I switched it anyway just to make sure.
Switched it out, now the smoke is coming from the bottom of the left side of my engine, also from the cables (both).
I cannot start the car at all it just tries to turn over but wont and starts to smoke so I stop.
I am needing help, again.
I am in such a bum mood I just need this all to work out.
