What size battery do I go with if I change my engine size from a 3.8 v-6 to a 350 rocket in a 83 cutlass? Do I stay with what should come in the car originally? What to do?
Not to start an argument, but in 35 years of experience GM dealerships I disagree. While there definitely a PIA with jumper cables, if you loosen and retorque a side terminal once in a while, and keep them clean, they'll last forever IMO. I've seen far more issues with bolt-on terminal ends of any type, which is why I'll only replace an entire cable, never just a cable end. GM has recently started to phase top terminals back in on many of its vehicles, but it was likely for cost reasons rather than reliability.megaladon6 said:BTW, side terminals are junk!! you're much better off replacing your terminals and using the top posts. i used to see tons of problems stemming from the use of side terminals.
