So, where do I start....
A long,
long,
long,
time ago in a distant galaxy....
I picked up this Regal project from a friend, its been sitting in a field (storage, well sorta') for some time. Originally, when I built an '87 a long time ago, this car belonged to friend of mine. I sold him the '87 3.8 and TH350C out of my Regal (that I proceeded to install a '76 Buick 455/TH400 into). I bought this one off of him after he later let the 3.8 freeze and bust.
So, fast forward a few years, I find a '80 B-body car crunched on one fender with a running and driving Buick 350/200R4 I snatch it out, sell the heap for scrap. I order a Poston GS350-110 (no overlap to build compression in '71 up motors...) springs and valve seals. The plan was stab the 350 Buick in place of the 3.8. Same motor mounts, same accessories/brackets. I have built a few G-bodies that required more brain surgery, 'this ought to be easy'...famous last words. I air up the cylinders on the 350 to swap out the valve springs, that's odd, none of them seal up, guess I will have to spring for some head gaskets, pop the heads off for a quick valve job...that exposed the cylinder bores to a proper inspection...this was easy cam and springs swap...now valve job...and some piston rings...little moisture had found its way onto the bore of a cylinder or two...flip it over on the stand to knock the pistons out. That starts with the oil pan coming off, nothing major there, pop off the first rod cap, copper, now that is a color you just don't see on a bearing surface all the time...well, what do you know!??! All the bearings looked like that, a matching set, rods and mains, in the copper...this was going to be an easy cam and spring swap right!?!! So, a day or two of trove-ing on craigslist netted me a '74 model 350 two barrel motor, 'stuck' he says. $50 for it and I'll load it, he said sure. So, swapped to the cap screw rods, one block was 030 over with nicer bore, and the stuck motor had a sweet un-turned nice standard crank....so cam, lifters, springs, valve job (oh yeah pocket ported while I was grinding valves, a used set of adjustable push rod from v8buick.com, rings, rod and main bearings, umbrella seats for the valves, head gaskets, gaskets, oil pump rebuild and wear plate....now its gets really interesting, I borrow some of those really long drill bits for 'opening up the oil pickup passage that runs along the oil pan in the side of the block, you know, to open up to 5/8" to increase oil supply...first drill no problem, opens it right up, second drill, the 5/8" that is like 28" long, yep, it decided to come out the side of the block, half way down...this was going to be cheap and easy cam and springs...Poston Buick has since went out of business. I forgot to mention that at the valve job deal, I bought a 1976 Electra 225 with 76,219 miles, starts, runs and drives, cold A/C, 455/TH400...so, I have soldered up the block, its assembled.
Here are some pics of the beast as of three days ago:
I had picked up the wheels a long time ago, something that was 15x8 and cheap. I blacked out all the trim when I first brought this car home (8-10 years ago), in an attempt to spike an interest in the car. At that time, and some now, I don't dig the colors on this car, I could deal with the gold/champagne color, but, mixed with chocolate brown interior that is the pillow/couch type nixed the deal.
Under the hood:
I have spent a little time in here since with some various bomb cans of paint...
I also deleted the top trim, slapped on some '87 tail lights. I have procured a 3 inch Glasstek hood that is in dire need of fiberglass repair, as it blew up/off at speed...hey, it was cheap, and this was going to be easy. I also picked up a GN hood that is sorta' tweaked.
So, I will try and stay on this track/project. The Jeg's dual exhaust crossmember just came in this evening. I have the aforementioned Buick 350, wearing a Poston S-divider that someone butchered into a Torker II style plenum, a 625 Demon carb, HEI, manifolds, cheap chrome valve covers, an open element breather, and an NX Hitman plate. Backed by a TH350 with a B&M Torkmaster 2400 stall and a TransGo shift kit(that I plan to install tomorrow).
The plan is to put this combo and probably a 3.42 gear together. Go back gold, pick a hood, I dig the GNX fender louvers, so I'll spring for them and the bumper fillers, probably powder coated black bumpers, maybe powder coat the stainless rocker panel trim black as well, and some cooler wheels....oh, and a GN spoiler, and maybe a set of Regal GS emblems....
I know its a freaking novel, sorry.
A long,
long,
long,
Under the hood:
