I am in the process of building a 350 Chevy. Right now, it has stock 70's pistons, and I think I should invest in some aftermarket ones. I will be using vortec heads, stock head gasket thickness, and just an average dual plane aluminum intake. From what I've researched, my heads have about a 63cc chamber volume. I have no idea where to even start as far as which pistons I should be getting. I'm using the stock bore, as well as stock crank, rods, etc. I will be running a comp cams XE268 cam (.480 lift, 268/280 duration) Can anybody lead me in the right direction?
