I've read tons and tons of threads about the "best fit" rads for our cars and the best I've come across is some that need a little trim here or a nip and tuck there or special brackets... what aftermarket, sizable radiator that's enough for an eventual 400hp max small block Buick 350? 110%drop in, factory hardware, mounts, etc but is aluminum, has fittings for trans cooler, and fits in the stock location and of course is thicker than the stock V8 radiators. Any suggestions? I was eyeballing this one, but I don't know for sure. Never bought a non factory replacement radiator before. And from what I can tell the inlet and outlets on the motor and rad are just about the same from Buick to Chevy.
http://www.summitracing.com/parts/sgt-cu162
****EDIT****
I think this is the fan they used, seems good.
http://www.summitracing.com/parts/rnb-620-118
****EDIT****
