Hey guys Im currently searching for a 80's El Camino and want to get more power and a little better mileage out of it. I hate dealing with 8 miles of vacuum lines and a measly 150hp and 240 torque aint gonna cut it. My goals are 275-300 HP and 325+ ft/lbs torque. I also plan to keep rear end gearing between 3.08-3.42 range. My goal is 25 MPG while cruising at 65-70 MPH on the freeway. If I could squeeze more out if it I would be ecstatic. I am thinking maybe a TPI 305 with a little head work, a small performance cam, with intake and exhaust. Or a LT1 motor with just a open air intake and a good exhaust. If I can find a good deal I would consider a 4.8 or 5.3 LS swap but think the work and cost would be more than the others. Also I cant do much to the swapped engine cuz I have to deal with California emissions. So if I swap to a newer motor, that motor must keep its smog equipment operational. I will be doing all the work myself. Which swap would be best for my power and mileage goals? I know this is not a Honda but I want to drive the car on a regular basis, go on long trips, and use for camping, so want some good mileage to go along with some decent V8 power.
