Blinker issues
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
Okay. When I got the car the signal lights would flash the left side but not the right. The 4 way flashers would flasher everything but the right front. And the indicator bulbs in the dash worked.
The other day I tried them and the tail lights would light up but not flash, nothing from the front and no dash indicator bulbs.
I've since replaced all the bulbs in the dash, replaced the flasher for the turn signals and the front signal light bulbs.
Now the tail lights flash, but still nothing from the front and no indicators In the dash...
I'm not really sure where to start with this.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
Check it at the column. Front turns are lt blue and dark blue, rear are yellow and green in the big flat plug on the passenger side of the column. If nothing there, I'd replace the turn switch.
popeye1978
236
210
I agree with fleming442 that your Turn Signal Switch (TSS) is suspect -- it sounds like the Turn Signal Flasher went bad after a bulb "went bad" (bulb or bad ground at the bulb) and maybe something weird happened that with the new Turn Signal Flasher the full 12V is going through the TSS and did something with the old switches inside the TSS
... which makes me wonder if your taillights are lighting-up when you hit the brakes
That means you swapped 5 parts; did you do that all at once or did you replace a part, test response, then replace the next part, test response, and so on?
83StreetMachine
395
819
Central NJ
Probably low on fluid......
Sorry I couldn't resist.
But I agree with the above. It's probably the switch. Just probe around with a test light and let us know what you find.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
Sounds like a good place to start, thank you. Hazard lights to the same thing
Maybe it's in the column somewhere.
Nah didn't do everything at once. Changed all the dash lights two weeks ago. Changed the flasher yesterday. Then tested the front sockets with a meter, they had no power to the flasher but I threw the bulbs In anyway.
Brake lights are working properly.
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
Just went over with a meter and tested the two blue wires, they each started at .3v and climbed all the way up to a whopping 1v, obviously that's my problem...
Until I tested the rear turn signals and they did the same thing. WTF... Shouldn't something somewhere be closer to 12v?
druggles85
Pendejo
Oct 25, 2009
282
468
Exeter, NH
And they're working... Well sort of but replacing the switch seems to be the answer.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
If they are working I wouldn't change the switch. I'd spend my time on tracing the wires to find out where the problem is.
