Oh well, that T/A manifold should work just fine, it's a dual plane.
http://www.taperformance.com/proddetail.asp?prod=TA_1235
Hmmm, I guess the holes can stay. No extra EGR holes i could see, and yeah the actual EGR valve sat in the back of the intake manifold.I think you might be confusing the EFE crossover with EGR. That passageway is there to heat the underside of the carb so it gets to operating temp faster. It is absolutely necessary in the winter time for good fuel atomization. You get winter in Iowa, yes? IIRC, Buick used a passage in the intake manifold to route EGR gas to the intake ports. Where is your stock EGR valve located? At the rear of the intake? If so, just changing to the TA manifold will eliminate the EGR. Some early Buick EGR systems were weird. I had a '74 350 that had holes drilled in the heads and the intake, that passed EGR gas from the exhaust crossover to each individual intake port. I used those heads on a '68 350 so the holes had to be plugged.
