Brake Booster Dissasembly
pontiacgp
blank
Mar 31, 2006
29,270
20,425
Kitchener, Ontario
Who has taken apart the brake booster. I need to take mine apart to use the pushrod that I will modify to use with my manual set up. I know there is a strong spring in the booster so is there a need to tie the thing up so I don't take any low flying aircraft out of the sky?
Thanks....page 1 of 140.....:popcorn:
Reactions: melloelky
I took them apart before it wont shoot across the room.
I tried that a long time ago. The push rod did not work for what I wanted. Maybe you will have better luck than I did.
What are you trying to do Steve?
