X2.I have always used a deep well socket, a universal swivel and a long enough extension to get away from the pedals and dash. Good luck, under dash stuff is always fun (NOT!)
Still can't get it. The fuse panel, steering column, pedal assembly, and the lower part of the dash are all in the way. I've stopped myself before I set the car on fire
Two things. A) does the hose to the brake booster have a one way valve that's functioning. If you don't have one it may help to hold the vac in the booster. B) you can bench bleed the pedal in the car. I've done it many times. Especially after you've installed it. Its just easier to pop off the lines put the "special" bleed lines on and go to town.
