I need to know the smaller brake line tubing size, is it 1/4? This going from the proportioning valve to the right front caliper. Thanks.
Cool thanks. I get .180" on the caliper. I will pick up a premade line, no bulk tube 3/16" tube locally in stock and a tubing bender now to figure out the length and I assume standard fittings for 3/16" tubing?
Just doing one line, all the torque of this 350 caused the header collector to rub through 😁. Should have moved it a long time ago.
