the container imbetween the brake booster and the hardline off the carb is a filter
the check valve is the plastic part that pops into the booster
if you try to pop it out, it will leak air until the booster is empty
if you are just touching it and you hear air leaking, the gromet/seal is no good and need to be replaced
They sell the valve and gromet in the "HELP" section at auto parts stores it should be about 7 bucks
