whatever youre going to put in it youll have to spend real money to go real fast.
put in something that you will enjoy working on.
Ive put a stock Buick 350 and a carbed turbo 6 in my 83 cutlass, for the fun of it.
In the end I preferred the SBB because it required less tinkering to get the performance I wanted.
The turbo 231 was a fun project, but stock turbo'd it maxxed out at about 10-11lbs boost before detonation became too much of a problem. It required rear gear change to spool and perform well. With turbos its all about the boost you can cram in there, so it was no world beater. I would venture a guess at mid-high 15s in the 1/4. Stock 78 321 turbo setup.
Probably about the same for the 350.
Generally speaking, I found the SBB350 more fun to drive, as the torque mentioned in previous posts gave it a better bottom end.
ANd call me a butthead, but the V8 sounded one helluva lot better.
