If someone who has knowledge in these parts please chime in, it would be greatly appreciated.
Never worked on a T-Type before.
Friend was complaining of fuel literally dripping onto his mufflers/rear axle.
So i jacked it up, crawled underneath. Above the rear axle, where the three metal fuel pipes that come from the fuel tank, then connect to 8" rubber hose section, then back to metal pipes that seperate to Left side chassis pipes, and right side chassis pipes...
1 thick (3/8) pipe and 1 thinner (1/4) pipe lead to passenger side
1 thick (slightly less than 3/8) pipe lead to driver side
my question is, on the passenger side, thick and thin pipes, do the pipes change size down the length of the car?
does the thin pipe, get thicker, and does the thick pipe get thinner, visually?
I would assume the thicker 3/8" would be the feed to the rail and stay 3/8 all the way to the front, but it doesnt look the case.
