You guys really took this thread the wrong way. I was just trying to get some data collection on what it would take to build a drag car on that level. The hellcat part of it was meaningless other than a benchmark. Never said I would or wanted to attempt to build something like this. Just wanted some knowledge and different perspectives. Maybe even help some people out at the drag strip. The thread was started more out of curiosity. If most of you feel this was about modifying a “Grandma” G body for performance, why didn’t you just stick with the factory smogged down 5.0 or 3.8 and call it a day.
As I said, G bodies have quite a few disadvantages. If you really want to build Hellcat killer out of one, you need to start with the frame. G body frames are weak and floppy and can only safely stand up to 400 hp if free of rust damage and has bracing installed. So you will need a redesigned frame that is much stronger than stock. There are a couple of aftermarket G body frames you can buy or have a race shop build one.
Next is the body, which works in conjuction with the frame. Again, a rust free stock body with racing will only stand up to 400 hp with its weak mild steel construction. Modern car bodies are made out of much stronger and lighter steel alloys. Instead of joining the body to the frame with body bushings or metal spacers, the two should be welded together to form a qusi unibody G body. The aerodynamics for G bodies are also very poor by modern standards and would need to be addressed. Good starting point would be to use a Aerocoupe as it has the best aerodynamics for G bodies.
After the body and frame are taken cared of, next is the suspension. G body suspensions are really outdated and victims of factory cost cutting. The front suspension design is recycled from old 1960's GM designs that has horrible geometry. The rear 4 link is so bad it would require a complete redesign. It is why the GNX is unique among G bodies in that it forgoes the 4 link for a different design. Developing and installing the various Nanny systems modern cars use into G bodies is beyond the scope of most DIYselfer. Then rear axles, brakes, powertrains, etc. You might 2ant to go over to Montecarloss forums and look up posts by a engineer named MAP who explains the many shortcomings in G bodies.
I still have a smogged 5L, and it can easily outrun my 2008 CVPI. If you know what you are doing, you can get a so called smog motor to perform. Sadly, knowing how to hotrod old gen engines is rapidly becoming a lost art. Just because G bodies are granny cars does not mean they can be improved, otherwise GM could not have made the pertormance sub models such as the MCSS, 442, and TRs. However, there are still practial limits in place for G bodies. Even at stock power levels, the performance G body modrls suffered issues. GNs often have distorted and warped body damage from their power output. You can still race prop planes, but a jet will still kick its *ss.
