C5 rear Corvette brake assembly
Griffin84ss
279
200
48
Corinth Ky
Hello All, I have a Quick question I can pickup a complete setup of c5 rear Corvette brake parts for $100 my question is that a pretty decent price for them??? Thanks for any info you brilliant minds have.!!!
Is this something that you would buy and put on your car?? I'm going to read the link and thank you. So is A $100 a good price?
I like that system since you can have a working parking brake and it doesn't need the springs and lever on the cvaliper for the parking brake. I drive a stick so for me a parking brake is required. If you are going to convert the rear to disk I don't see why you shouldn't use the C5 set up and your getting the parts for a price that sounds reasonable if all the parts are in decent condition. What is included in the parts for $100?
Reactions: Griffin84ss
Everything down to the nuts and bolts I'm gonna do I'm gonna buy them tom.!! Thank you sir I appreciate your honesty and respect your opinion.!!
Reactions: pontiacgp
I just looked on rock auto and wasn’t sure what corvette a gen 5 is but a 2005 model you can buy nice shiny new parts for a pretty reasonable price so you may want to do a little price shopping before purchase I have 98-02 camaro rear disk on mine and those are more than adiquit so I would think corvette brakes would almost be overkill but cool looking
You can also use the kore3 rear kit fir the gbody. http://www.kore3.com/proddetail.php?prod=10390-01
I would give tobin a call there. He had a wealth of knowledge for brakes.
I used their front brackets when I did the c5 brakes up and all lined up perfectly im sure the rear kit is the same. You will lose the rear ebrake unless you get a kit that had the works which kore3 has.
The rear ls calipers are the same as Corvette with the exception of the material.
I wouldn't want to be without an ebrake after losing my brakes after a car show. But that's me.
If you're getting everything for 100 it's not bad if the pads are like new and the rotors don't need to be resurfaced.
