Re: cadillac 472 re/build, phase 2: planning and discussion
Polishing probably has benefits for high CFM high RPM applications but you'll just be hurting power.
Secondly, polishing has become one of those "hot button" items with all sorts of opinions. Do some research and you'll see what I mean.
Generally speaking;
Pro-Polishing People: Do it for keeping the combustion chambers and pistons clean to avoid detonation from glowing carbon deposits. (Notice how people did this alot in the 70s and 80s)
Con-Polishing People: Say polishing discourages a homogenious air/fuel mixture and creates hot/cold spots. They recommend sanding the piston top/combustion chamber smooth, and then hitting it with a bead blaster to give it a constant textured appearance as a Cheap alternative. The best way would be to get a coating, like the ones offered by piston companies. (Notice how all the articles for high end engine builds use coatings nowadays).
Make your own conclusions.
Heres what I did to my heads. Then I had them flowed and professionally ported. From a guy who does it for a living "anything more than 60 grit on the exhaust, and youre wasting your time. Any time polishing on the intake is wasting your time". He has done back to back flow bench comparisons to make that claim.
How they look now;
First of all DO NOT POLISH THE INTAKE. The intake manifold, nor the runners in the heads. The little bumps help to atomize the fuel.G_Body_Enthusiast said:...would polishing the combustion chambers do anything performance-wise? i have a thing for polishing metals and i figure the heads might benefit from a polishing all around. i'm also eyeballing the intake to polish its runners.
Generally speaking;
How they look now;
