That is indeed an 8.5” 10 bolt rear end. The squared off triangles at the bottom are the dead giveaway, 7.5” rears have what look like curved “fangs” there. It could be GN, but it could also be from an Olds 442.I think it’s an 8.5 10 bolt I was told it is a grand national rear end?? View attachment 238906
Thanks these came with 342 gears and 373?That is indeed an 8.5” 10 bolt rear end. The squared off triangles at the bottom are the dead giveaway, 7.5” rears have what look like curved “fangs” there. It could be GN, but it could also be from an Olds 442.
Correct. Not all came with the G80 PosiTraction option though, so be aware of that if making a decision on it. Do your due diligence.Thanks these came with 342 gears and 373?
Thx much appreciated👍3.42 came in the GNs.
3.73 came in the 84 H/O and 85-87 442s. (83 H/Os had 3.73 but had a 7.5.)
Of course, you could swap them out to whatever gear ratio you wanted.
How would you determine if it was done well or not? Just by how it functions/rides?Devil's advocate time
It does in fact appear to be an 8.5 rear center section
The 8.5 rear was used in a lot of applications over the years. There have been a few that were swapped into G bodies from other vehicles. Some done well, some not. None would be a direct swap, aside from the aformentioned G body models.
I would ensure that it is the correct housing before I would start negotiating on it. Chances are it's the real deal, but you need to go into it eyes open
