Bottom line.All I can say about OBD1 is this...
if you take out the ECM, take out or disable ALL of it. You can't just do a partial. It's not hard, but previous posts explain the things needed to do it. Older carbs and vacuum distributor is in your future. If OG old school is what you want, don't install anything you need a computer for.
On the potential of OBD1, I offer the following additional comments.
There's a fundamental catch-22 between efficient burn and NOx. That's what tripped VW up with their diesels, and why the EPA and California have different tailpipe standards. The lower the unburned and partly burned fuel -- HC and CO -- the higher the NOx, and vice versa. This is because higher combustion temperature burns more fuel but also creates more NOx, and lower combustion temperature reduces NOx but also burns less fuel. The EPA favors burn efficiency at the expense of higher NOx, California favors lower NOx at the expense of burn efficiency.
At the time OBD1 appeared, regular unleaded was the new normal and super unleaded was hard to find, so Detroit favored lower compression. Lower compression meant lower NOx, but also less efficient burn. Improving burn efficiency meant either hotter ignition or higher compression, either of which meant more NOx. While Detroit dragged its feet on fuel injection systems, California came up with an elaborate "NOx credits" quota system to allow some of the many cars that couldn't meet the California burn efficiency and NOx standards all at the same time into the state under the EPA standards.
As delivered off the assembly line, the 1983 Buick V6 was BARELY passing the California standard on all three points -- HC, CO and NOx. In my area only HC and CO are tested, but to get mine to show low numbers with California gas, I had to increase spark temperature to the point where the plugs started to melt. NOx must have been through the roof.
EGR is a form of "fake compression" that supposedly lowers HC and CO without raising NOx at off-idle, where you do most of your driving. My Buick also showed low numbers when EGR was disabled, but again NOx must have been through the roof, and anyway it flunked the visual.
Detroit did not start delivering cars that could perform well and meet all the standards until they bestirred themselfs to implement SFI. Initially these cars still used OBD1. Many still had distributors.
The OP doesn't care about any of this, of course. But hopefully it provides some background for what he and many others are looking at.
