Atleast my 8 year old (the Jr. Mechanic) knows what a carb looks like.One of the young guys from work came over. He walked into the garage, looked at the row of carbs on the wall and asked "Are those carburetors?"
I pulled all the computer stuff out when I swapped to a V8. I run a regular q jet, non computer controlled carb, and an older trans. Hopefully later this winter I’ll be swapping my engine too.
Most modern mechanics are not trained at all to work on pre OBD2 cars. They are really quite helpless around old iron anymore. If you own a old pre OBD2 car you better know how to work on it because most mechanics won't nor would they even want to learn.One of the young guys from work came over. He walked into the garage, looked at the row of carbs on the wall and asked "Are those carburetors?"
Understood. Thanks for the feedback. Before I make my final decision I'll work with my tech to make my final selection.CCC system is stand alone and separate from the main harness. If you have the OBD1 port then you likely may have a CCC system. Then again someone may have pulled it over the years the car has existed. Do you have an electrical plug going into the carb ? If so then as stated you can run what you have and have it work really good. Those setups worked really well when all the pieces were in place and I have seen them on some pretty hot motors working just fine.
However if you want it gone then you need an Non CCC Carb and Distributor which can be aquired new from your supplier of choice. "if" your car currently has an overdrive trans you will need to figure out how to engage the lockup function. "if" you install a non- qjet then there are also linkages and brackets and air cleaners to figure out. It is not rocket science but then again you cannot pull one off, install the other and expect to go to the store later that afternoon. It depends on your skill and comfort level to swap it out for something else
You know, thinking about your *specific* background and goals I'm about to say something that makes me want to punch myself in the head.
Better yet, someone do it for me to stop it coming out. No takers? Darn it.
Because you don't have much mechanical experience, will be relying on a paid mechanic making shop rate to do your work, and you aren't going to learn as you do the work yourself...
Maybe an *ack* couch cough, ls-swap *GAG* might be a better ticket for you. One they're installed in a stock formulation they just sit there and need little tuning or work. Any shop can work on them as easily as a newish truck. No special skills or lost expertise needed. For the price of a crate motor, new Trans, setup to run the lockup, buying carbs and dizzy, all the hours to set it up, tune and make it work... ls may be way cheaper and easier for you.
It may be more reliable, quicker to enjoy, and cost less to get going for you in your unique situation.
Meanwhile, I'm going to go throw up now for having actually suggested there's a place for them.
