CAN THIS BE FIXED
gbodykeise
16
OK PULLED MY RAGTOP OFF LAST NIGHT BECAUSE IT WAS OUTTA THERE AND I FOUND THIS UNDER IT .. SMH WHAT AM I TO
DO??? CAN IT BE FIXED YALL??
gbodykeise
16
Haha yeah u right
Sent from my SPH-L710 using Tapatalk
Clone TIE Pilot
3,900
2,680
Galaxy far far away
You may be better off finding a better shape car. That rust damage looks very extensive. That area is where the roof is welded to the rear quarter pannels, hardtops had lead put over the seam, vinyl tops just had seam sealer. It seems quite often the seam sealer fails, leaving the weld seams exposed to rust. Welds rust faster than the base metal.
pencero
1,466
25
38
Ind.
'can it be fixed' is a different question than should it be. If you're paying insurance / registration on it the answer could easily be no. If it's sitting in the garage not bothering anyone and you have the $ you can easily fix it though... Make sure the repair is done once done right you don't want to run into a problem during an inspection (if your state has a tough one)
LS1GN
600
8
Central Florida
pontiacgp said:
what is the rest of the car like?
I agree - is the other side similar? Rear quarters? Frame rails?
If this is the only significant rust on the car then weld in new steel.
gbodykeise
16
Its ok not the best shape car..
pencero
1,466
25
38
Ind.
Well let's see it I'm sure you didn't remove that vinyl top for nothing - can't wait to tear mine off. Worst case scenario if your weld job comes out bad you could always opt for a new top to cover up the scars
