Yep, I got into Mopars in High School, learned to keep spare good distributor in the trunk.
Fun fact, a lot of people would put one of those 4 pin modules onto a heat sink and wire it to the Ford distributor to get rid of the Duraspark box. The Duraspark has about the same reputation as an Optispark for reliability.The one for the 301 should be the same. Just stay away from the $15 units, they are pretty much crap.
HEI is fairly simple, once the reluctor produces the signal the module then triggers the coil and produces spark in its simple form.
Similar to Ford's system except Ford has the module mounted on the fender and then triggers the coil. GM's HEI is all self contained in the distributor, which makes it very convenient. I have a GM style HEI unit for Ford 302 but haven't tested yet. It's a basic unit I picked up from Falcon Global.
I few years back I put the Ford electronic setup on a 65 Mustang that originally came with a point system and it really woke up the engine response on the 289 2BBL. The unit I used came off of a 78 Granada with a 302/auto.
The main Achilles heel of the HEI is the pick up coil. The two small wires break over time and then you have a "crank-no-start" condition. In the interim as the wires wear out, which is prior to breaking, is when you get all the goofy stuff that's hard to diagnose. Even the ohms test can come back ok, yet the pickup coil is on its way to being junk.
How about an HEI that grenaded shards of metal? ...
Helped a buddy build a V8 S10 day after it was on the road he smoked a mustang racing. Shortly afterwards the truck would barely run. When checking it out the rotor bushing was gone. No spring, no button, just gone.How about an HEI that grenaded shards of metal?
As I said before, I do not have good luck when it comes to engines, so hopefully this proves it 🤔😭😭😭
This came off the 305 of my Pontiac, not sure if this happened when the engine finally went driving down the highway in Madoc, or just from over time but when I took the cap off to use to run on the other one?
Well there wasn't much underneath, and theres rust all over too.
Now THAT is an incredible tidbit to know about. Could make starting up much easier.Thanks!!!you can use a 5 pin HEI module and have a switchable 10 degrees of timing retard.
Wowsers I never knew any of that. Now I have to go see what I have been using all these years. I am pretty sure if not OEM Delco then Standard which used to be my go-to brand. I once stripped a Turbo TA and I figured the coil was a bit better and I have been using it ever since.some info on the pickups.
